No way, leave them alone.
You will effect centre steering point. You're steering will be heavy, as mariocinq said you will eat tyres, because it will also effect toe out on turns. As fingers said you will massively increase the stress on bottom ball joints and track rods, not worth it.
Just read the number on the back of the wheel that starts with an e or et, then correct that to as close to standard as you can.
