Hello there,
was just having a little tinker with my car (a nice little T reg Fiat Seicento 899) as it has been a bit lacking in pull. I had read that this could be due to a problem with the lambda sensor/fuel air mix so I got the manual out and had a little nosey.
As it turns out there seems to be no lambda sensor on the car....is this normal? I found the spot in the exhaust downpipe where it is supposed to sit but there is just a bolt in there..no sensor. Also had great difficulty in finding where the lambda sensor electrical connection is supposed to be.
Any help would be much appreciated!
All the best!
Jonathan
All the best!
Jonathan
