adzorg1986
- Dec 13, 2014
- 13
- 2
Hey guys im in need of help with a fiat seicento sporting on a 51 plate
I got the car just before Xmas from a guy who said the car needed a new o2 sensor as the car wont go over 3000rpm well when i got it home it had been sat for a few days over Xmas before i started work on it and i found alot more faults with it but the two main ones are is this not revin over 3k rpm and now the engine has a tapping noise coming from the top of the engine, iv changed the oil and filter and changed the coolant as only water was used before, and nout has changed i pulled the o2 sensor out and the engine service light came on so i take it it cant be that can it? i found a fault code of p3000 witch is a random misfire but for the life of me cant figure out what is causing this.
As for the tapping from the engine i have no idea what is causing it as i don't want to take the head off but if i cant find away to sort it then i will have to and do a gasket change at the same time.
any help on these issues im having will be great as im at the end of my car knowledge on this.
many thanks
Adam
many thanks
Adam
