I have fitted it. But the cars not on the road yet, so can't say how it performs.
Although it does sound pretty loud with just the manifold
Bear in mind that this manifold is designed to fit a punto, as I've mentioned in another post. This isn't a straight bolt for bolt replacement.
If you have the ability and access you can make it fit, it is longer than I originally thought, so I am having to do a bit of chopping and welding. But my exhaust is not standard.
If you have a standard cinq spi system, just cut off the bottom flange of the manifold and cut the original pipe to suit. The manifold is stainless, so I would advise getting an exhaust expander and swell the cat pipe to fit over it, rather that trying to weld it. This also allows you some scope for future improvements also.
I am not familiar with a sei mpi system, so I couldn't advise as to what to do.
If I had some pics from under the car I could estimate. I am happy to measure anything, now it is on the car because it's sat on a four post ramp at the moment, so I can get at it easily.
