| Seicento Type R | Clonking noise My car has started to make a clonking noise from the front it only happens when in a low gear sometimes only makes it once when you set off from rest, but some times if you leave to car to roll with clutch out and dont accelerate it will make a clonk with every full turn of the wheel? Read through pete FAQ and it could be engine or gear box mount. What is the best way to test and find out if it is this and if not what else could be wrong with it? TIA James www.clubcento.co.uk
| Summit stuck in the grooves on your brake discs? otherwise could be driveshaft probs, but not too sure. Pete. Cinq sporting 1242cc Cinqs&Seis Yahoo group Clubcento
| | #3 | ||
| Nothing's Impossible! | Lift the bonnet and try to move the engine by pushing it back and forward. it should be stiff but if there's excessive movement, 1 or more of the mounts may be shot. Best to do this with the car on ramps and you'll be able to get a look at the gearbox mount while you do it. Mine had a clonk and vibration when accellerating, found the gearbox mount shot and exhaust was hitting the anti-roll bar. Hope that helps Wanted: Exhaust for my Cinq Sporting! PM me!
| | #4 | ||
| Seicento Type R | Sorted it now it was the front drivers wheel that was about to drop off [:0][:0][:0] been there before and spent 4hrs at fiat as they thought it was the drive shaft[:o)] but its was the wheel that was droppin off. cheers for all your help though James www.clubcento.co.uk
| Noise from Air Vent/Turbo | Lou | Ulysse | 7 | 07-06-2004 04:27 |
| Transmission noise. | Morty Mort | Lets Talk FIAT | 7 | 27-05-2004 20:08 |
| | keef444 | Bravo / Brava | 2 | 24-03-2004 02:51 |
| | Paddy_Punto | Punto | 2 | 25-12-2003 18:42 |
| | syphon123 | Cinquecento / Seicento | 2 | 01-03-2003 02:11 |
