fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Dec 20, 2014 #21 Won't be the TDC sensor. It really doesn't know (or care) which cylinders are firing.
OP OP J Jim Haseltine New member Joined May 30, 2008 Messages 28 Points 7 Dec 26, 2014 #22 Well, whatever I've done, the mixture seems to be ok now and the misfire is gone. Still seems to be a bit rough at idle though and the rev bouncing is back - not all the time and clears if you switch the engine off and restart it.
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Dec 27, 2014 #23 Worthwhile swapping out -- or removing and good cleaning -- the throttle body. Hunting idle is usually idle air control problem.
