- Jul 22, 2014
- 228
- 123
Seicento Sporting SPI 2000
Right, on to my next job.
When I had the wheel arch liner out to replace water pump/cam belt, I noticed
some lumpy corrosion on the metal brake pipe as it loops over to enter the inside of the body (front drivers side).
Metal pipes on both rears were changed at a garage earlier this year.
Quite fancy doing this myself to learn more about the job.
Done plenty of reading and my list is for some copper/nickle 3/16 pipe.
Some M10x1 fittings.
New flexi pipes to both sides with new clips.
Brake fluid.
Brake spanner.
A bleed kit of some description, a pipe cutter and a flaring tool..
Now then, any suggestion for a not hugely expensive flaring tool...
This one seems to have good reviews?
Draper Expert 23312 SAE
Only problem I foresee is that the bleed valves in the calipers look well rusted..
One is fairly rounded off, the other is OK in shape but very rusty. I've been soaking them for a week or so now whilst doing other jobs.
Any advice or gotchas would be welcome before I start...
Phil
Brake fluid.
Brake spanner.
Phil
