I've stripped down my 1.2 8v block ready to rebuild it but I'm having trouble removing the dipstick tube from the block I need it out so I can get to the core plug behind it. Is the tube a screw in or push fit?
Also I have all the Pistons and rods out and weighed so that I can match them. How do they seperate or don't they. I've got 2 assemblies exact 1 is 10 grams heavier and another 6 grams out so was going to seperate to see if it was the piston or rod that's out
The block is a 188.a4 from a mk2 punto mpi
