Technical Mpi brace on a Cinq
Northampton
Got a shiny new OMP Mpi Seicento brace for my 16v Cinq and when i try and shut the bonnet it's hitting the brace near the battery :mad::mad:
What am i doing wrong??? The bracket on the offside of the bar does look a bit like it's been welded on at the wrong angle :confused:
The straight one is the Seicento Spi brace. Ecu bracket sits on top and i cut the coolant bracket in two. Seen this one on loads of Cinqs :confused:
Can only think it's cos i've got the car jacked up and i'm bolting one side down first then the other. Gonna try it with the front on the ground tomorrow and do all 6 bolts bit by bit.
Doesn't just rub on bonnet a bit - bonnet completely rests on it! Needs to sit at least 30mm lower :bang:
There are two types of MPI sei strutbraces
One for models fitted with ABS
One for non-ABS models
Its possible you have the first one, which was designed to bypass the ABS box/system
Its been a while since i have owned a sei and im semi retired but if i am correct you will probably have to get rid of it and get the non ABS strut brace
Regardless if which one you have it should fit anyway. It's on the right way round for sure since it's impossible to get it the wrong way round.
I was under the impression this brace is the only mpi brace, with the other two omp braces (Straight and straight with a bend) being for spi sei and cinqs.
As long as the brace is flat on the strut tops it should fit perfectly (unless your car is bent :p )
Is the underbonnet design slightly different between cinq's? That may be your issue...
Thought exactly the same about all of that (y)
As far as i'm aware it's not been crashed. Never been declared and can't see any signs of accident damage.
Just had a look at a Seicento Mpi with the same brace and couldn't really see any differences other than they had adjusted the bar to be longer.
You've got the pictures of my Cinq there. I've cut part of the bonnet away to accommodate the brace as well. You might find it also hits the washer jets too, but it may not.
The hole locations for the brace have also changed as you spotted, but that is to change the suspension geometry, rather than move the brace.
James
That engine bay looks awesome! Could I ask what performance mods you have done?
