My daughter's seicento 2004 sporting lost all it's coolant a couple of days ago and it would appear that the water pump is goosed as is the head gasket (the compression differs across the cylinders).
So new water pump and new head gasket....
I've got a source for a gasket set inc valve stem oil seals inlet/ex etc; water pump; cam belt; head bolts; tensioner; alternator belt and oil filter plus I have large drums of 10/40 synthetic oil and anti freeze.......
So all's good. I've done heads etc before so no worries there but have now spent hours searching the internet for the info I need. I've got the cylinder head bolt torque settings (30Nm,+90,+90) but I cannot find a definitive answer to the ORDER of the bolts. I have this info: 8,6,2,5,10,7,3,1,4,9 which is unconfirmed but I don't know which bolt is 1,2,3 etc anyway.
Please can somebody confirm the bolt numbers and removal/installation orders...
Looking at the car from the front is it numbered
1 2 3 4 5
6 7 8 9 10
or
1 2 3 4 5
10 9 8 7 6
or something else????
Has anyone had issues with synthetic oil? - I've got a 50L drum so it's cheaper than going and buying some semi (whether there is any benefit or not is immaterial).
Many thanks.
1 2 3 4 5
6 7 8 9 10
or
1 2 3 4 5
10 9 8 7 6
Many thanks.
