General funny noise after 50mph
it comes and goes sounds like engine but i could be wrong could be tyres imbalanced anyone else had this problame it pulls in a stright line not sure if tracking is set properly?
You can do more than 50?!?! Lol sorry.
I'd probably start by checking the wheel bearings for roughness/play mate.
Jack it up and give them a spin/wiggle
Well its just passed mot and my sei will do 110 easy im just saying noise accur at 50mph+
I've no idea. Need better description.
Not sure how to interpret "pulls in a straight line". If you mean that when you steer straight, it tries to pull to one side, then it does need to have the tracking done. You may as well have the tyres balanced while you're at the tyre place.
Feels like a over rev vibration but sounds like engine noise slightly increese maybe?
Sorry, meant heavy right foot. I'm dyslexic left for right (except in Italian and politics).
Lol my bro is dyslexic cant spell a thing just wondering to doing gearbox oil change i have wet shaft box... how much needs to go back in and were is the gearbox cap? I see a black plastic cap but doesnt seem to come loose and were is the drain plug cheers
I don't know about how much you need but the drain plug is in front of the rear gearbox mount and the fill plug is on the front of the box. Black cap is the breather.
Won't take more than 2 litres. It's full when oil starts leaking out of the filler/level hole (12mm hex plug on front face of the box) leave the plastic breather on top of the box well alone -- they're easy to break.
Well i have bought hex set for oil change on engine so got the tools is the 12mm hex the drain plug or filter/level hole? And to drain it im goingfor the gearbox rear mount is this correct?
I mean infront of rear gbox mount* but were do i put oil in?
I can see drain plug and hex on front now but do i fill up this hole?
