Technical Idling problems
I live in boston, links, pe21 postcode. Ecu is magneti marelli, it says 600 sporting 1.1plus a whole load of other numbers on it. Mpi of course.
Ok, pre cat and post cat sensors. THESe are a new one on me. I guess they just screw out? Any experience of probs encountered would be appreciated.
The sensors will need a tap on a spanner to get them to unscrew no doubt.
It sounds like the non-MF59 one and those Ecu's are pretty reliable. The MF59 type suffered from corrosion on the aluminium heat sink and some of the internal earth connections became high resistance.
Would a proper garage type diagnostic check help. I have a ten quid obd2 reader which dos not throw up any codes.
MultiEcuScan shows the parameters/readings of things but is not cheap for the full setup. A garage would normally have the diagnostic equipment to read things but It's down to the person to interpret the readings to find a problem.
