I don't think the sensors come out, (without a lot of force/you might damage them). Now you have the TB off give it a good spray with carb cleaner or similar to get all the dirt out. If you're lucky that might sort it.
Will report back in couple hours. Its worth noting also that the EML does not come on at all and my OBD2 reader shows nothing. I was led to believe that an air inlet valve sensor would throw up an error code?
I have taken cc1 advice. Ran car with temp sensor unplugged. Bottom hose gets hot, rad fan cuts in very early and stays on. When I then plug in the temp sensor the car immediately cuts out.
I'm guessing this indicates a faulty sensor?
I have a new one to fit ready and waiting.
OR a wiring or connector fault.....I'm guessing this indicates a faulty sensor?....
