Hi all. Completely new to this forum thing so not 100% sure how it works. I posted this same question in the Newbies section but was told to put it somewhere else.
So i have a Fiat Siecento (first car). It has been going fine without problems. A little while ago i was driving and it slowed down and stopped. At first i thought my petrol was too low (i have only recently started to drive) however it wasnt that. So i restarted it after 5- 10 minutes and it would drive fine for a few minutes then slow down and stop. The car seemed to act like it was overheating & cutting out the engine. I would pull up for a while then it would drive fine. So thought maybe it was overheating. and thought nothing of it. I had it checked over as i had a MOT due the next week and wanted it to pass. So I took it for the MOT last week (and it passed) and on the way home it broke down AGAIN.
What seems to be happening is overheating and the engine is cutting out. If it is left for a few minutes it will start again but repeat the overheating and cutting out continuously.
However the fans are working perfectly fine and i don't think the car is actually over heating.
On the diagnostic computer the error P0115 is coming up which apparently means water temperature sensor so we replaced it for a new one- however, the problem is still happening.
it runs slightly longer than it did before changing the sensor however it is still cutting out repeatedly.
We think there might be 2 sensors but can only find one. Maybe a cam pulley sensor?
Just to be clear - All my waters, oils, etc are filled and the fans work perfectly fine.
Has anyone ever experienced this before or know what could be wrong with it?
All help is appreciated.
Sorry it seems to be a bit of a long essay too!
Thanks.
Thanks.
