rogerowen
The plastic bush arrangement that holds the bottom part of the gearstick, in my 889 Seicento, has fallen to bits. Would I be correct in thinking that I would simply need to pop off the 2 cable ball joints to access the broken remains and fit a new one? There's a small circular plastic bit and an 'O' ring lying there too - no idea where they go, might make sense when I get the old bush unit out. The arrangement seems to be coated in a white grease - has this got some special name? Thanks in advance for advice.:worship:
