donkey95
Hi, long story but... I have a 2002 (Phoebe) sporting which I absolutely:worship: The start of my saga was when my step dad drained and changed the coolant, he spilt a little of it in the engine and gave it a quick hose off.
The following day she was running lumpy after checking the plugs and leads for water (not the problem) she still ran awful. A friend used his tester thingy and it came up with the idle air control malfunction (the yellow engine light is lit on the dash display)
I got a replacement throttle body on fleabay which when fitted made the car rev up and down on its own.
I bought a second throttle body (fleabay) in case the first was faulty but car still runs rough except for when the air idle sensor is disconnected, then it runs fine.
Yesterday I undid the bolts which hold the throttle body to the engine to check the gasket, which looked ok. when I tightened the bolts back down one snapped off:bang: Step dad got it out with his screw extractors.
I now cannot find a bolt like it anywhere and the car still runs rough with sensor plugged in.
Any help and ideas would be most appreciated.
