Would this combination work sufficiently well to pass MOT emissions?
block: stock Cinquecento FIRE 1.1
head: P75, complete with mpi inlet manifold and 866 cam
ecu: stock Cinquecento, for start
I will have to get a 3 bar fuel pump, sort out the P75 exhaust manifold and slice the spi injector wire to drive the 4 mpi injectors. I guess that if the P60 ecu can drive them so should the cinquecento one.
Then 2 more unknowns remain:
Can the cinquecento ecu adapt the fuel parameters adequately based on the λ feedback? ( could 'help' it with playing with the fuel rail pressure ;-)
Will the cinquecento ignition maps be good enough? (I guess they will, otherwise the P75 cam to cinquecento mod would not work).
Just to clarify, I KNOW, this is VERY sub-optimal. I plan to either get a piggy-back ecu (DET3 seems promising) or an eeprom programmer for fine tuning at a later stage, but the cinquecento is my daily driver to work and I cannot afford it being off the road. I just need it to be no worse than the stock cinquecento engine.
PS: I do have the P75 ecu, but I see no benefit on trying to use that over the cinquecento one. Both will have the wrong parameters for the 'hybrid' engine.
