Right then this is where we are at,
Building a seicento track day car, for our oocwl track days at llandow track!
Weve dropped a punto p60 block in it, its been built to th2 following spec.
NEW crankshaft
New pistons and rings with new bearings
New water pump
New sump
New timing belt
New thermostat
Original head covered 66k
Full new gasket set
Was thinking maybe 866 cam
Supersprint manifold
New exhsust system
Personally I would of liked to turbo it as the turbo versions certainly turn heads at track days!
But ive read so much about how much hassle and costs involved!
I think weve missed a massive opportunity by not dropping in a 1.4 lump, but hey thats my bros decision!
Under the car ive done the following, new wishbones, new front discs, new front pads, serviced the calipers, new apex suspension kit, 40mm lower, new brake flexis, and run new copper break lines inside the car! At the rear ive had the beam off undersealed the entire car replaced bushes, fitted new springs and painted with black hammerite. Looks like new again all the rust is a thing of the past.
Inside the car weve stripped eveything, dash, all door cards, all seats, belts, carpets, and believe it or not me and my bro managed to lift it pretty easily.
Things im looking at doing:
Maybe runnig fuel lines inside,
Pair or sparco bucket seats
Omp roll cage
Lexan polycarb windows
Larger throttle body (unsure on the punto 1.2 16v larger body and spacer plate)
Induction kit magnecor leads
Yeah so there you go thats about it !
Any advice grately appreciated
NEW crankshaft
New water pump
New sump
New timing belt
New thermostat
Full new gasket set
New exhsust system
Omp roll cage
