Styling wheels
Styling wheels
H0use
Hello i wonder can i put wheels 165/65R14 on my cinquecento sporting. Now i am whit 165/55R13 and they are smol and too weak for Bulgarian roads. So can i put it without make any changes to the suspention only thing can make is tu put spacers so they can fit?
You could, but they'd be horrible. Really horrible. Ideally you'd need to lower the car for them to work, and you'd probably have clearance problems.
If the wheels are 5.5J then 185/50/14s are a saner choice.
The roads in the UK have been (unfavourably) compared to those in Nigeria.
I also had a problem with big holes in the road & Cinquecento sporting wheels. After damaging 6 wheels i changed them for Seicento sporting wheels, they are made stronger on the inner edge so they don't damage so easily, & they fit without having to change anything else.
You meen that it will be horrible becouse of the high of the tire. But look if the tire is 55 which is now what it hapans in bulgarian roads. See the pfoto wheel is so badly damage that strike on the suspention and it become trianguler shape. So if the ruber is 55 or 60, it better to be 60 but i am not shure can fit properly?
The white wheel i want to put they are 14" 4х98, 5,5 J, whit tire 165/60
And if you want to fit 65 profile tyres then its probably better idea to fit them to 13" wheels and not 14" ones. But it maybe a best idea to just fit wider tyres that have some rim protection too.
Although with all that said and as much as you probably don't want to hear this, i think the best possible thing you could do is just slow down a bit.
OK so i understand that i can put 165/60R14" but it's not a good idea.
And i have another question obut air filter can i remove this vale on the picture an the air box? The idea is to put sport air filter i see a lot of cinq in the forum without them.
My emergency light not work some ideas were is the problem? If i change the swich
And, you can also try me because i think you are the second Bulgarian over here after me :) I am in Sofia though, don't where are you ?
Oh iea but i am from Ruse.
Can i put side mirrors from seicento on my chinko they look pretty similar
And what is the diferents between them and what is the modification
Ok so the hazard lights there have no voltage on the swich but on the safe fuse have 12V constant the relay is Ok and the back wiper not working too and there have no voltage. I am looking for some wiring diagram of the car so i can easly fix the problem and make some modifications
It have some connection whit the radio whem the safe fuse is removed the radio not work have to chek haw is connect the radio
helo another problem. This time the back wiper not work. So i am looking for elektrical manuel or someting like that to help me fix the problem
Plenty of wiring diagrams about. Polish and Italian ones on the Peer 2 Peer networks (aMule, eMule, Limewire, etc.) Haynes manual, etc.
But check for 12v (+ and -) at the connector and check the fuse. It's probably not feasible to repair the motor -- should be possible to get a new one, or find one at a scrap tard.
Hey from wheels to the engine here are some pictures from repair and i have question haw to clean the engine blok (surface where the gasket ley) and the piston whithout remove the piston? Here ar some pictures of clean head.
