| | Thread Tools | Search this Thread |
| | #1 |
Posts: 7,762 Thanks: 16 Trader Rating: 0 | Mystery Flatspot Hi Guys and Gals, Just the other day my Cinq has started some really bad hesitation problems and feels like it's not revving cleanly. I searched the forums and have narrowed it down to the following order 1. Most likely Lambda Sensor 2. Possible Map Sensor 3. Maybe fuel filter My main question is will a Diagnostic show up faults without any warning lights being seen on the dash? Any help or advice appreciated. Cheers Liam
__________________ Yes it's really me! 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND |
| | Quote
Posts: 535 Thanks: 0 Trader Rating: 0 | Re: Diagnostic Testing? Hi, Check for signs of head gasket leaking if there's no warning lights on, water in the oil, oil in the water etc...... Thanks Paul T
| | Quote
| | #3 |
Posts: 495 Thanks: 1 Trader Rating: 0 | Re: Diagnostic Testing? Sometimes yes but most times no. As the computer is a lot slower than the ecu anyway so you only see 1/20th of what is happening anyway. As long as the plugs are good and leads are good and you have a good spark from the coils then it will more than likley to be a slow lambda sensor. no responding quick enough when throttle is required. Lamdba sensor only work at light throttle or when cruising. They do not work at full throttle or when deaccelerating, at this point the lambda goes to open loop allowing the full fuel mixture to be entered into the engine, a slow lambda does not go open loop as quick thus trying to keep the correct fuel air ratio of 14.7 /1 and that then gives the hesitation.
__________________ F.I.A.T. -- Flipping , Italian , Automobile , Tat . |
| | Quote
| | #4 |
Posts: 7,762 Thanks: 16 Trader Rating: 0 | Re: Diagnostic Testing? Decided to start with the cheapest items to eliminate the possibles, these are plugs and leads. I'll get some decent insulated pliers and see if I can get a good spark from each one then I'll move onto the bigger stuff. Does anyone know how to test coils with a multimeter? Thanks Liam
| | Quote
| | #5 |
Posts: 7,762 Thanks: 16 Trader Rating: 0 | Re: Diagnostic Testing? Update, check plugs and leads, seemed fine, erm coolant and oil seem fine too, I'm puzzled. Liam
| | Quote
| | #6 | ||
Posts: 1,178 Thanks: 0 Trader Rating: 0 | Re: Diagnostic Testing? Liam Sounds like a problem that i`ve been dicussing with a guy on here called tom,he tried everything even replaced the lambda with a new one,still had the hesitation so he took it to fiat for a diagnostic check and it turned out to be the lambda,(the new one he had fitted was faulty too) Car now runs fine Cheers Adrian
| | Quote
| | #7 |
Posts: 7,762 Thanks: 16 Trader Rating: 0 | Re: Diagnostic Testing? God Adrian, I was following that thread and I do hope it's the Lambda or MAP or indeed something other than the head gasket! Oil is fine looking, plugs are fine as are lead but on start up it's more sluggish than usual, sounds lumpy or rough on idle and has numerous flatspots through the rev range in any gear though with time will still do 110 with coaxing! I wonder? Liam
| | Quote
| | #8 |
| | Re: Diagnostic Testing? Liam didnt it stall the other day or summat for ages then started bak up! Perhaps whatever is causing these problems also caused that!
__________________ ![]() 2001 Modded Sei Sporting - GONE!! CLICK ME FOR A CENTO CHUCKLE - http://www.fiatforum.com/cinquecento...ease-help.html MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html |
| | Quote
| | #9 |
Posts: 7,762 Thanks: 16 Trader Rating: 0 | Re: Diagnostic Testing? Liam didnt it stall the other day or summat for ages then started bak up! Perhaps whatever is causing these problems also caused that! Got it going like 5 mins later and it's never done it again. Liam
| | Quote
| | #10 |
| | Quote
| | #12 |
Posts: 21,701 Thanks: 1069 Blog Entries: 3 Trader Rating: 1 | Re: Diagnostic Testing? It could be head gasket, but not between a cylinder and a water way, between two cylinders. At low gas speeds there is no compression because it is leaking into the other cylinder. At higher engine speeds the engine will appear to run normally. Cheers chum D
__________________ |
| | Quote
| | #13 |
Posts: 7,762 Thanks: 16 Trader Rating: 0 | Re: Diagnostic Testing? I have been thinking this D, do you think it will show up on a simple DIY compression test? My mate has one from his K-series days. Liam
| | Quote
| | #14 |
Posts: 7,762 Thanks: 16 Trader Rating: 0 | Re: Diagnostic Testing? Update: Tried the car today with the new MAP sensor and it wasn't any better, well maybe it was but I felt it still isn't revving cleanly through the gears. Will get a hold of the compression tester and hope for the best. I've ruled out Lambda since th ewarnign light hasn't come on after nearly two weeks of strange running. Liam
| | Quote
| | #15 | ||
Posts: 1,178 Thanks: 0 Trader Rating: 0 | Re: Diagnostic Testing? Hi Liam I wouldn`t rule out lambda i don`t think Toms warning light came on and he had 2 different faulty lambdas. His diagnostics check only cost him £30 at his local fiat dealership,could have gone on forever changing bits but would never have sussed the brand new lambda was faulty!!!! Cheers Adrian
| | Quote
| | steviecol_uk | Cinquecento / Seicento | 4 | 15-08-2005 19:26 |
| Asda Jaffa Cake Mystery FAO Paul | Charlotte | Leisure Lounge | 23 | 21-10-2004 18:04 |
| The Mystery of Time and Space [Again ;)] | Stu DemonD | Leisure Lounge | 55 | 11-10-2004 08:37 |
| | goofygolfer | Punto (Mk1) | 2 | 30-09-2004 19:58 |
