| BEN IS A SMACK ED!!! | doggy sei , any ideas? hey jumped in my sei today 2 go 2 the beach with my m8s 2 catch sum rays! and i started my sei and revved it as it can get spluttery sometimes due to the 75 camshaft but it was a dog i revved and it was bogging loads for about 15 sec's i was kinda worried then it cleared and giv e aloud reving noise then it ran fine? any ideas, not a sign of bad things 2 come i hope? it happens every now and then but today was the worst?
__________________ Its got.. ~ Migilia spiders in Graphite Grey ~ Custom stainless exhaust 3 1/2" rolled out tip ~ GSR induction kit (red) with cold air feed ~ Pipercross ecotek breather Fitted as oil breather(red) ~ Abarth Kit fitted ~ Punto 75 Camshaft ~ Soon to have , Novitec chip, 40mm Tb from tricker. & sei sporting seats covered in Black leather!!. http://img169.echo.cx/img169/8436/benjosh7qp.gif | ||
| Re: doggy sei , any ideas? ben pls read u'r PM's!!!!!!
| | #3 | |||
| Re: doggy sei , any ideas? shouldn't really rev it loads as soon as you start it mate, let it try and idle before you do that. but then evry car is different i guess ![]()
__________________ ![]() <Team Alex> ~ Speed ~ Of ~ Light ~
| | #4 | |||||
| | #5 | ||
| Drives a Punto | Re: doggy sei , any ideas? I always blip the rev's a little when I start up the car, a bit of a habit I guess. Only about 4k, nothing serious. On a similar note, does anyone know if pushing the clutch down when starting the engine is beneficial? I do that aswell, again as a habit ![]()
__________________ 3rd Fiat - luck as good as ever | ||
| | #6 | ||||||
| mad bad and very very old | Re: doggy sei , any ideas?
1) Pushing the clutch when starting will take the gearbag out of the equation and stop any drag from the gears slowing the crank speed down. However, how much drag can there be from gears in finest hypoid oil. 2)Pushing the clutch can also mean you are pushing the crank against the thrust washer increasing drag rather than reducing it. In my opinion, don't touch the clutch after you have returned the car to neutral. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||||||
| | #7 | ||
| Drives a Punto | Re: doggy sei , any ideas? Thanks D So turn key and don't touch anything ![]()
| | #8 | |||
Cheers D
| | #9 | ||
| Re: doggy sei , any ideas? It's generally recommended that you don't exceed 3000rpm with a cold engine, but ideally you wouldn't even rev it that much. 4000rpm is far too much! I'm not sure about pressing the clutch pedal when you start, but that's what I've been taught at my local IAM (Institute of Advanced Motorists) group. I have wondered whether it is actually beneficial, and will probably query it some time.
| Some Ideas on Spraying Sei Interior | Leroy | Cinq/Sei > Styling | 9 | 21-06-2005 23:38 |
| black sei sporting in fairfield (south wales)? my sei sticker on boot | benfredjosh | Spotted / Was It You? | 0 | 23-05-2005 10:52 |
| ABUSE OF A SEI !!! | jebs | Cinquecento / Seicento | 16 | 02-12-2004 22:58 |
| lowered my sei | fordy | Cinq/Sei > Technical | 5 | 12-07-2004 18:49 |
| My Sei | Silver_Sei | Members Motors | 5 | 10-08-2003 02:33 |
