so far there there hasnt been much progress beside the trip home on the recovery truck :/,coming down the slip road ,changing down gears because race car and boom,no selectable gears . engine off check stick all is fine,start engine,not going anywhere so diagnosis was clutch and thrust bearing,
already had another clutch to go on,new thrust bearing ordered,ribe bit set also on the way oh and discovered leaking water pump,well bearing was shot so no point putting coolant in and go way of the vw air cooled
since then water pump got fitted and timing ended up out,silly me didn't put marks on ,
so re timed,turned by hand,went to start and tensioner broke so it jumped resulted in bent inlet valves :/.
so weekends work is looking to be rebuild head and new cambelt and tensioner,got new valves to fit ,so collecting new tools i like having a full toolbox!
oh and my sexy wheels may get fitted this weekend if ic an get tyres swapped for favours.
soon be back on the road miss upsetting the local boy racers in my ickle cinq.
