My va cinq turbo keeps failing its mot test. Previously on first test it was running rough found timing to be out so corrected that, another lambda,cts, new high pressure fuel pump and fpr set correctly, new map and all vac lines checked, exhaust leaks sorted, oil and filter change After this ran and drove a lot better took it back yesterday to fail again but not as badly as the first readings at fast idle were
Co 2.307 max limit.300
Hc 157 max 200 this passes fine
Lambda .953 max 1.030 min.970
Same on second idle at idle
Co 1.983 max .350
So tested suggested a new cat as maybe age, mileage, and poor running buggered it up so put new cat on. sure enough old cat seemed quite blocked up.
took it down today didn't do a full test but failed again :bang:
So any ideas. Car has done about 30 thrashed miles always done test hot not sure what's next with it any help appreciated:worship:
Co 1.983 max .350
