So I fitted another throttle body the other day after breaking my injector and since then I'm getting a strong smell of fuel through the vents when I turn the fans on. Have checked for leaks and splits in breather pipes but found nothing. Any ideas?
Obvious checks would be around throttle body -- probably best done with engine running.
Finally found where the fuel smell is coming from. The breather on my rocker cover is heaving out smoke.
Is there anyway I can sort this out as I'm having to drive with the window open
Unless your MOT man is blind it's an automatic fail. The gases from the breather must be re-circulated as per Mr.C's suggestions.
If the gases are very petrol, rather than oil, it could be that your oil is petrol diluted aqnd the petrol is evaporating.
I happen to be a mot tester but it's not due till October anyways so win win lol
to be fair, they do smell if you just have a filter on but they shouldn't really smoke much - not visibly...
Check the flame trap in the pipe isn't totally clogged up, i'd be tempted to do a compression test at this point myself.
But if its been like that for ages it could just be that the filter is totally full of oil and that starts smoking a bit once the engine is upto temp.
Flame trap? It's just a piece of empty rubber pipe :s
