a bit tricky ? its easy fella , if you have a set of ramps you can do it ,, i can do it on a jack its two 13mm bolts and a 17 iirc and thats all you need
mate if i was still living in york i would have been in my car already - it really is easy as you like. Infact any of the gearbox mounts and engine mount are super duper easy..
well don't pay much if you get them to change it. In a garage with a lift we are literally talking 10-15mins tops for the whole job.
i would just get them from ECC if i were you, they will come fast too..
http://www.eurocarcare.net/search/finder/73-20/
both of them, the engine mount rarely goes so don't worry about that one. Look in members offers section for discount code
so I need to buy two mounts as in the link?
where's the other one located? Didn't look for two when the car was ramped!
I 1
Meh, I can live with the odd rattle and clonk, passed it's mot so bogger it.
you got a multimeter??
Yup, needs tested with a multimeter to check charge rate. Engine off (battery level), Engine on and again with everything you can find to turn on running.
Normally battery light signals a weak charge and the battery draining faster than it's charging. Though check the connection to the alternator, i found mine was doing that on and off and it was just the terminal loose (probably from when my rear mount went bang and the engine was swinging back and forth, the wire was getting wiggled more, so given your mount seems gone, defo worth a quick check considering it's free and only takes a few seconds!)
