if you forgot the bundle of earths as ming mentions it probably won't even turn over - i forgot that one when doing mine and pretty sure my code system worked at that point.
If the Code light is on though, you get no fuel or spark, thats how the immobilser works on these. So are you sure you got matching key and codebox for the ecu? In mine i put the new codebox on and then just taped the new key to the antenna and stuffed that up behind the dash away from the ignition so it didn't pickup the old key.
