Technical Passing through the Firewall
Jacques993
Okay so trying to wire in an amp and having issues with the power cable, I have removed the plastic cover behind the foot pedals & tried passing the cable through with no luck. Am I doing something wrong? Do I have to drill the hole out?
Thanks!
I did same as scott, it's right next to the throttle, if you poke a screwdriver through you'll see
Yeah was trying this for ages earlier, cable goes through but seems to run somewhere, but putting a screwdriver through you hit a hard object almost immediately?
I never had this issue although mine was about elbow deep ? If thats any help no longer have a sei to check for you
Just had a quick look, my wire comes through a gromit I cut a cross in directly behind the throttle. Didn't have to remove anything
Mines a S reg sei
I seem to have these 2 grommits on the right of the engine bay & also, the grommit you talked about has a scew cap and looks like this... so not sure if the same?
