Hello everyone, I have finally had enough of my cinq and it's poor starting. So I have swapped back to the 900 ecu for now.
If I turn the key the fuel pump runs for a bit, turn one more click and she turns over but takes an age to start. I have an iaw16 er-f ecu with a gazzaman chip. Once running, she is bang on. But it's just this starting malarkey I have to get sorted. On the 900 ecu she fires first time, and after a couple of hundred miles from first being connected settles down and runs fine, albeit not as nice as with the 16 er-f ecu.
Am I using the correct ecu? I have a chips2race chip, but this doesn't work. I assume it doesn't bypass the immobiliser. Woj has offered to bypass the immo circuit a while ago, but I just want to make sure there is nothing obvious I am missing?
Cheers Huw.
Cheers Huw.
