Lamps by Post - For all your lighting needs
Thread Tools
Old 21-12-2013   #1
Rear wiper removal and debadging
Is removing rear wiper an easy job?
Also will be debadging, many different methods, I'm thinking the tooth floss method seems as it's virtually impossible to demage paint.
Dom
Thanks henseyseries3 thanked for this post
dpashley42 is offline Reply With Quote Quote
Old 21-12-2013   #2
Moderator
jatkinson is part of the official FF Events Team :)
jatkinson has donated!
Re: Rear wiper removal and debadging
Yes , its easy to remove , you need a bung to fill the hole ...
Debadgeing is so easy I took i washed my boot with hot water then the badges came off a lot easyer
jatkinson is offline Reply With Quote Quote
Old 21-12-2013   #3
Moderator
Old 21-12-2013   #4
The Renegade Master
Razman's Avatar
Razman has donated!
Not just Cricket Champion
Quote Originally Posted by jatkinson View Post
Hot water helps muchly. Just don't do what I did and attempt to use a kitchen scouring pad to take the glue off!
The rear wiper is 3x13mm bolts under the boot lid. You can then use a grommet to bung up the hole. The wiper itself is 1x10mm bolt under the little cap (I think it's 10mm).
I went a little further and welded a little plate behind and filled over it and painted, quite easy to do yourself actually
It's a never ending battle of trying to make the cars better, and trying to be better yourself.
-Dale Earnhardt
Razman is offline Reply With Quote Quote
Old 21-12-2013   #5
Please put the motor and arm in the for sale section of the forum someone sure to need one.
Vandals and water ingress.
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 24-12-2013   #6
Ok thanks lads! One thing though, the debadging video is for a suby wrx, obviously my seicento is a lot faster so will it make any difference to the badges?;-)
Once the -60 springs are on (it's an SX, dont panic!) It will be time for some tidying up. Il make a thread i think.
Dom
Old 25-12-2013   #7
Moderator
-60 are for pussys Lows ftw
Old 25-12-2013   #8
Honeymonster has donated!
I can feel a Christmas edition of Max Power coming on...
The only thing that ends up low is your bank balance if you take J's advice.
Likes dpashley42, jatkinson, blu73 liked this post
Still here but normaly over there...
Always late but worth the wait.
Honeymonster is offline Reply With Quote Quote
Old 25-12-2013   #9
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Snowboard Slalom Champion, Skate Boarder Champion
to get your badges off, fill your kettle to max, boil it, go to your car and slowly pour water all over the badge. Boiling water is hot enough to really soften the glue, they will just come off easy, i keep pouring while pulling badge gently but careful not to scald your fingers.
Might need something to clean any sticky residue off after.
blu73 is offline Reply With Quote Quote
Old 25-12-2013   #10
Moderator
dont use boilng water , you could end up damaging the paint , if you use a hair dryer/ hot air gun you can heat up the panel around it so you dont damage the paint (Y)
Old 25-12-2013   #11
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
really...? i done this hundreds of times and never ever had an issue, infact rescued my uncle the other day who was doing it with a heatgun and had damaged his paint as they are way way hotter than hot water from a kettle. Yes it will soften the paint slightly but any heat will. It will only be about 90 degrees by time you get outside with it and paint clearly gets hotter than that in alot of countries just sitting it the sun and their paint doesn't melt (well maybe after a long long time they do lol)
Also how i remove any stickers/graphics made of SAV off paint or glass. Let it cool down, clean and polish, job done.
Likes oldhammer liked this post
Old 26-12-2013   #12
Trader Rating: 5
fingers99 has donated!
Hot water or hair dryer (I keep one specially -- way better for heat shrink than anything else) is the safest option.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 12-03-2017   #13
How easy is it to remove the rear wiper motor? I've taken the back pannel and have all the wires etc out but there are 3 rivets holding the motor in please...any say way to get this out?!
beckyedmonds is offline Reply With Quote Quote
Old 13-03-2017   #14
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Quote Originally Posted by beckyedmonds View Post
I think the rivets are holding the motor together. It should have bolts to undo, after you have removed the arm outside.
D
Old 13-03-2017   #15
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
from memory (been a long time) 10mm nut on the wiper arm, take arm off. Then inside 3x 10mm bolts holding the whole assembly to the bootlid.
Charmander - Panda Mania 1242 mpi 8v - thread
Sully - 500 1.3 Mjet - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT
Thread Tools
(T) Rear Wiper Removal ascott92 Bravo 7 03-04-2011 15:38
(S) Rear Wiper removal. Mk2 Jack00743 Punto (Mk2/2b) 3 16-06-2009 21:57
(G) Rear Wiper Removal smokeyjoe03 Punto (Mk2/2b) 4 14-05-2009 15:59
(S) Rear Wiper removal How? Smally Grande Punto 29 31-03-2009 11:41
(T) Rear wiper blade removal. HARWOOD Grande Punto 1 02-12-2008 10:48
