Any ideas what there is on the timing end of the engine that can leak, slowly?
Chii seems to like leaking coolant out from time to time. Sometimes when shes cold, and not driven far. Sometimes when shes drivnen miles and is well up to temperature.
I've only ever seen drips with the engine off, but then i don't tend to park up, get out and look with the engine on through fear of being run over (no handbrake), or through fear of overheating.
From what i can see, the water is dribbling down the timing side of the engine, and then collecting near the back of the crank pulley and then dribbling off and down the sump.
Apart my car being too low to climb under and have a decent butchers, some clot has put all manner of gaurds, belts and pulleys in the way.
Whats up there, wheres the water pump, do these engines have core plugs that may be leaking?
Confused!
Confused!
