I own an Seicento MPI 2002 I was driving along changing gear when all of a sudden the gear stick went sloppy so I pulled over. When I released the clutch found it to be stuck in reverse.
I checked that all ends on both cables were still connected that go to the gearbox selector from the gearstick and they were. I disconnected the ends from the gearbox and pulled both cables back and forth and both cables did move as they should and they seem OK. I then checked that the gearstick would move to all positions while the connectors were disconnected and it did. Am I right to think that the plastic gearstick mounting and the cables are OK in this case? If these are OK what could be the possible causes?
