Technical Cinquecento lowering springs!
Jamieoneillbmx
I got some lowering springs brand new off ebay (eibach) ones i dont know how low they are so if i measure them could anyone tell me ? Allso are they easy to fit would appriciate some tips thanks
Just put them on measuring wont help. There's guides to help fit I would put on with new shocks and top mounts saves having to do it all again in a few months time. Get decent spring compressors for front and make sure they are properly located. I would also start puttin pen oil (not wd40) everyday for at least a few days on all bolts that you'll remove
Totally agree...I had to replace all the shocks and mounts after 3 months....fitted shorter shocks as I didn't feel the original length shocks were working too well with the shorter springs. Lowering springs kill old and worn suspension parts.
If the new springs are not more than 40mm lowering, they should be OK. Otherwise, you need shorter shocks. Check that the springs are still located properly on full droop (all weight off the relevant wheel(s) as though you'd been launched off a large bump or a hump backed bridge).
Check that the car isn't running on the bumpstops.
The advice about top mounts is good.
These are the springs ImageUploadedByFIAT Forum1378561454.847621.jpgImageUploadedByFIAT Forum1378561466.428274.jpgImageUploadedByFIAT Forum1378561478.563243.jpg
Only paid cheap for them brand new
This is whats on the springs would appriciate of anyone knew how much lower they would make my car. ImageUploadedByFIAT Forum1378561967.790486.jpg
I dont have a sporting i just have a cinquecento s. but to me the aprings look big. And im just hoping i dont have to change anything to put them on
I will thanks for the help and how long does it usually take to fit springs ?
