Have bought a Fiat Cinquecento Sporting threw ebay and had a message off the seller, after I had paid a deposit, saying '' since the advert was posted it has started to burn a bit of oil at startup and at full throttle, this is down to a split or loose stem seal. Due to this I'm willing to drop the price down ''
any ideas on what this problem may be ? and how much it would cost to fix ? thanks in advance for any help
If its on start up and on full throttle its either stem seals or oil rings
Expensive!!! Unless you plan to do it yourself,
Stem seals is an involved job,
Head off
Valves out
Stem seals out and then replace
Budget £130 quid for parts if your doing it yourself as you will have to replace all top end gaskets including the headgasket
Youll need .....
Headgasket set (get the best you can afford, payen or genuine fiat) around £45 stem seals will be in the set
Head stretch bolts (again get the best you can afford payen is one id reccommend) £12 - £20
Budget for exhaust studs as they do break
Plusgas (to help get those tricky bolts out) £5
Maybe if you are going to mod budget in a skim £45-£60
A whole bunch of jubilee clips as the standard ones are fubarred once removed
Then theres the tools youll need
Valve spring compressors
A half decent socket set
Torque wrench for the head bolts
Pliers
Screwdrivers
And maybe even more
Theres a guide in the guide section youll pretty much be doing a headgasket
Then whilst its all apart you may aswell do cambelt and waterpump aswell as a service
Cambelt kit £45
Waterpump £25
Oil filter £3 ish
Oil £20-£30
Airfilter £ ???
Fuel filter £5
If your handy with the spanners its a doer upper but unless the car is immaculate and fairly low mileage I personally wouldnt pay more than £200
If your not handy with the spanners id avoid it
Just my 50pence worth others may disagree
Lee
