Well fingers is a real spanner man I also need the plus gas a old style in a drip by drip can... and the special spanner from Halfords but as well I use a butane torch cycling the sequence heat the union set torch other side of car park cool by dripping plus gas go for cuppa last union took Friday to Sunday midday.
the tools are more expensive than slave cylinder
if you are really good you can strip out the old pistons and replace all the rubber bits if there are no scratchs or corrission a rubber boot kit may be more difficult to find you need a bottle of meths for this to get everything clean with.
the pivots will need redoing next summer even if you dismantle and applay merest trace of copperslip
id do the leaking cylinder soon.
