There is also a possible further confusion, as all early Seis were fitted with the 'rugby ball' wheel, but not all contained an airbag.
D
Does the sticker relate to the airbag.... or the pre-tensioned seatbelts?If it has an air bag, then there should be a date sticker above the drivers seatbelt?
Blu -Why are you so wide?
Why do you need this info????....Where is the ecu/module for the air bag unit ....
Well thats something i never knew, do you think this could be correlated to the early sei's that did not have PAS??
