Hi all. For anyone that´s been having problems with the idle on spi 1.1, I thought i´d add the solucion to my own. So, since i bought the car 3 years ago it had a high idle, 1000-1200 rpm getting worse with the pasing of time 1400-1600 rpm. After a garage changeing the belts, filters, oils and plugs it got a bit worse. Investigating, seemed that the pipe from the carbon filter that goes to the map had a leak. Changed it completely, from tb to carbon filter to map sensor. Made it a bit better but still hunted.Also saw that the 2 fine pipes that go underneath the air filter housing were put on reverse(i think), the tb pipe goes to the M mark and the one from the air intake to N. Correct me if i´m wrong. The other day i decided to dismantle the throtle body, to find out the the gaskets where fubar, beetwen the manifold, the separator piece and the body itself. Removed gaskets, cleaned up, replaced gaskets with gasket paste, carefully, also added on the rubber gaskets between the 2 TB parts to make sure no leaks and all sorted now. A nice and smooth idle. Hope to be of use. Sorry no pictures but it was bit of a flash-op.
