| | #91 | ||
| Re: 6F/16F Cinque/Sei ECU Reader Project Please can somebody post their data on the injection duration at idle in normal conditions (warm engine)? I'm getting rpm around 800-850 and injection duration == 0.800 ms usually, and it seems that ECU just can't use injection durations of smaller values. Haynes manual also says than normal inj. duration at idle rpm should be 1.5 ms. So if anyone able to post their data (screenshot for example) on injection duration (for example in fast inj/rpm mode (s key)) this will help me very much. p.s. May be i've got faulty fuel pressure regulator, so to much fuel injected over the same periods? Or it is broken fuel injector?
| | #92 | ||
| Re: 6F/16F Cinque/Sei ECU Reader Project I am ignorant when it comes to this... What is required to build my own cabel/connection? I would love to be able to read faultcodes as the cinq just failed the Swedish MOT due to emissions ... is it the kat, lambda or worn engine... Cheers, M
__________________ Everyday: Audi A4 TDI ![]() Pleasure: MGB 1969 ![]() FUN: Blue Cinq 97' | |||
| | #93 | ||
| Re: 6F/16F Cinque/Sei ECU Reader Project Has anyone actually got this project completed ??
__________________ Wanted : Nothing at the moment | |||
| | #94 | ||
| Re: 6F/16F Cinque/Sei ECU Reader Project Wow! Would any of yous know how to get the p75 ecu's rev limit up to 8500rpm from the little i know the tables only go up to 7100rpm you all are rather intelligent so cant see it being very difficult
__________________ Seicento 1242mpi turbo Nissan primera 2.0eGT Honda Civic aero deck 1.8vti | |||
| | #95 | ||
| Re: 6F/16F Cinque/Sei ECU Reader Project heya! can someone plase post some pics of the actual working hardware interface circuit? im interested in messing a bit with it thanks
| The FF ECU Reader...? | ben | Lets Talk FIAT | 37 | 29-12-2006 19:25 |
| | hangten | Bravo / Brava | 3 | 29-09-2003 02:57 |
