hi all
took my seaicento sporting abarth for an mot which it failed on over a few things
but the one that iam looking for info on part availabilty is they gave an advisory on the Steering Column Top Bearing saying its slightly worn ,certainly if you grab the steering wheels at 9 an 3 position and waggle its side to side you can feel a bit of play.
any idea if you can just replace the bearing or is it a new steering column
and any ideas where to get the parts
also prior to the mot i stuck in 15 litres from the light just coming on of shell super unleaded as well as a bottle of that Nitrox hot shot ( i had it in the car anyway ) and thought ok it would help with emmisions....err it so didnt car failed its lambda reading and exhaust emmisions carbon monoxide at idle excessive.
car is needing a new lambda ( ive got a new bosch one to fit ) and the centre exhaust pipes leaking
any suggestions on where to get front suspension wishbones car needs one due to a busted ball joint cover ( will replace in pairs ) was on ebay and they go from 20 each upto around 60 for QH ones is there a tye that are better than others ideally OEM or as good as but its hard to get OEM quailty these days.
anyhoo thanks for any help. Cheers Stu
