Hi everyone,
I am in the process of planning a 1.4 16v engine conversion for my seicento schumacher.
I wont be doing it until I can get some suitable insurance (have been driving a company car so no claims bonus yet)
Anyway I am planning to find a suitable donor stilo to use. This seems the simplest way forward.
Anyway the fitting of the engine seems simple enough, its quite well covered.
However i was wondering if people knew how interchangable fiat sensors are between engines specifically sensors between the mpi engine and the stilo 1.4.
My plan is to follow honeymonster's cue and use a det 3 piggyback as it is perfect for this and makes wiring much simpler. However the mico ecu i have needs to not go into limp home mode when connected to the 1.4 engine.
I am hoping i can fit all the mpi sensors to the 16v engine, is this possible. Or are the sensors on the stilo compatable? Am not expecting it run the engine well, but i dont want it going into limp mode.
My other question is, can you fit the stilo exhaust manifold? Is it a good design?
I saw a thread where on a turbo car a bracket was made to move the radiator away from the manifold. It was on a turbo car but am hoping it will provide enough clearance?
Finally, i plan on using the stilo inlet along with fuel rail. Is the fuel rail compatable with the mpi fuel line? Does the mpi fuel pump provide enough flow? I know it provides enough pressure!
Do i need an external fuel regulator? As per a cinq conversion? How does the mpi regulate pressure?
If anyone can answer any of this i would be grateful!
