I understand this is a common problem, where one pair of cylinders corresponding to one of the coil pack misfires. I get a fault code of P0352 associated with Ignition Coil B error/fault.
I note that if the ECU believes there is a misfire, then the fuel injectors on that pair of cylinders also stop injecting.
In this case I have a spark on 2 and 3, but seemingly weaker than cylinders 1 and 4.
I have swapped connector and plug leads between the two coils and still a misfire on cylinders 2 and 3.
I have swapped the plugs around, swapping 1&2, and 3&4 around and the problem still exists on cylinders 2 and 3.
I have an oscilloscope on the ignition drives and they look rather different. Are there any waveforms I can compare these with?
All this does suggests that the ECU ignition driving cylinders 2 and 3 is faulty.
Any thoughts? Anything to avoid paying out for a new ECU!!
