Hi everyone,
Further to my thread about my sei cutting out, I thought it was due to operating the brakes, but that appears to not be the case.
As fingers alluded too it may be the rad fan, now this doesn't come on, I think that the car stalls when it tries to start the fan. But I am not sure.
Luckily I have an calibrated ir temperature monitor, so was able to measure temps in the engine bay. The rad was about 90 degrees with the top hose about 85 degrees. The engine varied but was approx 70 degrees.
So the car isn't overheating. The fan doesn't appear to be seized, so what else could it be?
I have heard That the mpi cooling fan arrangement is more complicated than the spi.
The ecu controls it? Does it use the engine temp sensor as a reference? Where is the controlling relay?
Is there anything else it could be?
