Charlie292
- Oct 2, 2012
- 6
- 4
Hi all, realize this bit of the forum is for Seicentos and Cinqs, but some of you lot might be able to help me with this one.
My 1.1 Punto needs a new gearbox asap, I have found a box from a 1.1 Seicento that is local and at a good price. I've had a search on here but cant seem to find anything properly conclusive as to what I'm after.
Question is, can I go ahead and buy it and put it on the Punto? The casings are the same I know that, and I'm not worried about any issues with the gear ratios etc, the car just needs to get me to work and back over the winter.
What I need to know is this "new" box has a cable clutch and the Punto is hydraulic, can they be swapped? I know I can swap the clutch arms over, the cylinder itself is what I need to know about, the Seicento one seems to not have the holes needed to mount it. Can I swap over the entire gear change mech on the top of the box from my old one to let me use the holes from this?
Thanks in advance. Charlie.
