bishy
- Sep 12, 2012
- 55
- 12
I all started work on my fiat seicento schumacher today and, well EPIC FAIL
Ist problem, I could not get the rear dampers off! soaked in WD40 for ages, but even if I did manage to get the bottom bolts off then I cant see how that you can get at the top ones without a ramp and proper tools?.
Thought this would be the easy job! damn.
Got the car started, runs well, but the rev counter does not work?
Also the power steering does not seam to work either as its stiff as hell untill you get rolling??
At the moment the altenator is broken, so that's another job so wondering if only running on the batt is not giving the car enougth power to run the power steering + poss the rev counter?
Thanks in advance
Thanks in advance
