The FIAT Forum
Old 16-05-2005   #1
MotorWorldChink's Avatar
Trader Rating: (0)
Handbrake Adjustment
Just fitted pads, shoes and handbrake cable. Brakes need bleeding again they spongy. Had to fit a mew master cylinder one side was siezed. Handbrake cable is a tough one. Got the cable to the tightest possible place yet i can pull 7 clicks and don't get resistance till the fourth. Sure this aint right.
MotorWorldChink is offline
Old 16-05-2005   #2
Cento Boy
surfin_fella's Avatar
Trader Rating: (0)
surfin_fella has donated! Australia
Re: Handbrake Adjustment
sure you've routed it right? And you sure the handbrake levers are on properly? If so, I'd get a new cable mate!lol
Sie - Proud advocate of Centoism
Cinquecento60
Clubcento - The UK Cinquecento and Seicento Owners Club Clubcento Forum
surfin_fella is offline
Old 16-05-2005   #3
Trader Rating: (0)
Its a new cable. Sure its routed right cos i just pulled the old one out and put the new one back in the same place
Old 16-05-2005   #4
Trader Rating: (0)
minijohn has donated! United Kingdom
Once you've bled the footbrake , you'll need to adjust the handbrake cable . If you get underneath the car , you'll find the adjuster just behind where the handbrake comes through the floor , right above the hot exhaust pipe!!
Just take up the slack until you have about 2 clicks of free travel .Make sure the wheels rotate freely with the handbrake off .
Too much free travel and no reserve travel are both MOT failures .
Hope that helps
John
minijohn is offline
Old 17-05-2005   #5
Trader Rating: (0)
Thats what i am saying. The cable is at the max end of adjustment and it's still not tight enough by a long way. Would it be possible that i have a cable too long
Old 17-05-2005   #6
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
is yours a late cinq? Does the handbrake adjustor system look like it does in the haynes manual. there was talk a while ago of two different types of cable, i dont remeber if it was the sei having a different cable.
If you have a late cinq, and the adjustment mech doesnt match that of haynes - then you have a sei handbrake adjustor.
Or i could be talking poo, i remeber reading it - but not paying too much attention.
arc is offline
Old 17-05-2005   #7
Trader Rating: (0)
It deffo looks like the one pictured in haynes
Old 17-05-2005   #8
Trader Rating: (0)
mckcrich has donated!
Yes, Arc's right later Cinqs 97 and 98 with the seicento type steering wheel also have a different brake lever and need a different cable. I know becaus I had to change mine on my old cinq.
Regards,
Michael
Michael,
Developer of the mckcrich chip - more power per £ than any other mod you can buy for your cento (or punto)
mckcrich is offline
Old 17-05-2005   #9
BlackSei's Avatar
Trader Rating: (0)
nope hes on a P reg with the cinq style steering wheel.
BlackSei is offline
Old 18-05-2005   #10
Cento Boy
Trader Rating: (0)
When I called for my handbrake cable, they asked for my chassis number to make sure the cable was right. Did they do that with yours? sounds like that could be the issue. Other than that, my money would have to be on the handbrake levers not being on correctly
Cinquecento60
Old 18-05-2005   #11
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
Liam has donated! United Kingdom
Have a read through this just for information
http://www.fiatforum.com/showthread....dbrake+mystery
Liam
CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline
Old 26-08-2008   #12
Trader Rating: (0)
bit late for this message but just for future refrence for other fiat cinquencento drivers if the hand brake is a new cable and properly adjusted and still moves then its the back shoes on the back wheel need adjusting and simple as that as that was the trouble with mine now there all good
reamzmc1234 is offline
Old 26-08-2008   #13
Trader Rating: (2)
ycming has donated! United Kingdom
hmm nope completely true, as there are a longer and a shorter cable.
and adjusting the shoe, you are only trying to centre the shoe.
Wanted : Nothing at the moment
ycming is offline
Old 26-08-2008   #14
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
No, you are adjusting the shoe on the friction adjusters.
PD
rallycinq is offline
Old 26-08-2008   #15
Trader Rating: (2)
hmm .. is that. that wee hole on the shoe, u put something in it ??
What does the friction adjuster do ? I never really understood it when i did mine
Thanks!
Ming
ycming is offline
(T) Handbrake Mystery Solved Liam Cinquecento / Seicento 22 28-04-2008 19:13
(T) Handbrake Cable Adjustment - How? leightoness Punto 2 16-05-2005 12:56
(T) Handbrake adjustment....plz help sr3309 Punto 7 16-03-2005 21:13
(G) 1993 1.0IE handbrake cables, cylinders, shoes and leavers. Louie Bee Uno 1 07-01-2005 23:04
(T) Handbrake won't go on! SnowBord Cinquecento / Seicento 4 16-04-2004 01:15
