Hi everyone
My friend recently bought a very low mileage 2001 seicento mpi.
Everything had been perfect with it until it started idling up and down and occasionally wouldn't start. The fault was intermittent but got worse to the point where it was undriveable, badly misfiring and idling badly etc
A little history that I know about the car, it had its ecu replaced and possibly the throttle body due to it being jump started with the leads backwards which fried some stuff.
I plugged my scanner in and pulled a P505 idle circuit malfunction and a cylinder 4 misfire. My friend bought a known good throttle body although I was suspicious due to the previous problems with the car.
I installed the new throttle body and there was no change! I started going through the loom and found the 4 wires for the connectors were soldered together as if the connector was cut previously.. Although this did not worry me
I wiggled the loom at the ecu connector and the car began to idle perfectly again! When I moved it again it went bad.
I checked for codes again and found this:
P505, P105, P130, P225, U1600
So my question is do I have a bad loom or a bad ecu, bearing in mind the ecu has been replaced once before and possibly the throttle body.
Thanks for your help!
Chris
Chris
