WayneCento
- Jul 14, 2012
- 13
- 2
Hi all.
I recently passed my test (4) days before this event and have been learning in my Fiat Seicento Sporting (S reg, 45k on clock) for a year. I really like the car. Ideal for city driving - very fond of it - far more fun to drive than any of my instructors cars.
However...
Within a space of 2 hours it got broken into (in an area normally regarded as 'posh'), stereo robbed, locks on both sides ruined, then to add insult to injury a load of steam ejected from the bonnet on the way home. Devastated
I'll put the violins away now and explain in detail so I may get some good advice from you.
I took it to a garage where they replaced the water bottle which was split. They also said they flushed it and added a new radiator fan switch.
They said they run it for ages with no overheating problems.
I took it back home (4 miles) and the temp alarm light lit up. I could not hear the fan kick in.
The next day I thought I would give it a short test drive with the air heaters on full in the car - there was a lot more slow traffic than I expected. The car drove fine and the temp light did not come on. I then stopped to switch the heating fan off to see if I could hear the radiator fan kick in. I could not. After running idle for a few mins without the in-car heater on, there was a pop, loads of steam and I discovered that the top radiator hose had split. There was no temp light at this point.
Then, with almost comical timing, the fan kicked in...
Oh, by the way when I was running the heater, there was a constant stream of warm air coming through. So I don't think its a heater blockage problem as I heard some suggest.
I have checked for some head gasket problems like emulsified oil but cant find anything like this. - Although I'm not an expert in diagnosing this sort of thing.
I have ordered a new radiator hose, but know that this is but a symptom of an overheating problem.
Some good advice on what my course of action should be would be much appreciated.
I never owned a car before, but I used to be an industrial printer engineer, so I'm pretty handy with a toolkit and am not scared to get my hands dirty.
Help Please!
However...
Help Please!
