JetStream
My little track car also in the for sale section https://www.fiatforum.com/classifieds/showproduct.php?product=26787&cat=all
Specs:
Tricker 40mm throttle body,
High lift Cam,
Custom Lightened and balanced *flywheel,
Gsr Induction kit,
Gsr Water pipes,
1.2 punto p60 lump,
New timing belts/pulleys,
All new gaskets,
New lightweight aluminium radiator,
New timing belt,
New water pump,
New engine mounts,
Powder coated water rail, engine mount and rocker cover,
3" Stainless steel exhaust system,
4 new wheel bearings,
Powder coated matching adjustable strut *brace,
Punto gt turbo front brakes,*
Vented, grooved and drilled front disks,
Rear drum brakes replaced for UNO turbo rear disk brakes,
Spax 50mm lower and stiffer shocks and springs,
Tinted indicators,
Carbon inserts inside headlights
Inside,
Heater matrix removed for lightness,
Fully stripped. Almost Everything possible removed,
Recently retrimmed red Bucket seats,
Battery has been moved into boot,
Custom real carbon fiber 2x2 twill dash with fighter toggle switches (needs wiring finished)
Omp alcantara stealing wheel,
Boss kit,
Sabelt lightweight 4 point harnesses
Vid of it running*
Specs:
High lift Cam,
Gsr Induction kit,
Gsr Water pipes,
1.2 punto p60 lump,
All new gaskets,
New timing belt,
New water pump,
New engine mounts,
Tinted indicators,
Inside,
Boss kit,
Vid of it running*
