Technical engine build plan
Danieljs
Rhyl
ok i have a seicento sporting mpi 53 plate, and been thinking about building a complete engine up for it, i have done this with other cars but not 100% on the fiat FIRE engines
so far i have come up with
1242 8v bottom end
*16v pistons and rods from a punto
My current Head mpi 1.1
75 Cam shaft
standard headgasket
wanted to go turbo but parts are far too hard to sauce, evern more so for the mpi, so im hoping this set up will be similar to a low boost 1.1 set up
ahh i was under the inpression the CR ould be withing a relitivly normal figure, im assuming sticking with the standard 8v pistons and rods would be ideal then,
Way, way, too low on compression. The only benifit from running the 16v pistons and rods in an 8v is a lower CR, and even then, some have calculated that it's a wee bit too low for charging. It'll be something under 8:1.
7.8:1 from what i have read.. ;)
The bit about parts being difficult to source has some truth, but the reality is that there's little of much utility out there for SPI engines, too.
Fundamentally, all you have to do is fabricate -- or, at least, alter -- the inlet and find (or modify) a suitable exhaust (or fabricate one). Get a decent welder on board and you're half way there. Then put together a (please God, not MF2 based) ECU/System.
Turboing any engine not designed (or, at least, developed) for it will always pose problems, but, then, getting similar outputs from an N/A engine will pose more.
