Hi all,
My seicento currently has a habit of stalling or almost stalling when warm. When you are slowing down and press the clutch in the revs will drop very quickly and if i am unlucky the car will stall. Usually it will just climb back up to idle revs.
Now this is charatistic of a vacuum leak, or possibly an idle motor fault? However what i want to know is what changes as the car warms with regards to vac lines or the idle motor? As when its cold it operates perfectly, pushing the clutch when slowing down shows the rpms dropping slowly and coming to a stop at idle.
I am inclined to think some part of the idle control changes as the car warms up. But can anyone shed any light on this?
If anyone can help i would appreciate it!
