Hi aol as you know iv turbo the 1242 8v engine using MF2
Still having a few running issues...now when the engine warms up it cuts out...it'll slowly develop a misfire only a slight one then just stall...but I realised if I unplug the MAP sensor wire it looks perfect son as MAP sensor is plugged back in same problem??...id of thought that the car wouldnt run without the MAP sensor tbh but it runs perfect
This is off boost in tickover problem it revs abd rubs fine just when warm it will not tick over...any ideas?? Btw iv changed MAP sensor it made a difference before it would cut out when cold bow when warm lol
